ok i will have a look on my digi dash tranducer 2morrow for you, defro three wires 1 is earth 1 is ign live and the other goes to digi dash
Thanks very much mate i'd appreciate that.
Stil need this help
right if you hold the transducer so the little bit that sticks in is at the bottom.
The above one is black.
Left is blue/red
right is earth/brown.
If you need more help let me know.
To repeat what a few others have said, some Novas (and presumably a few other Vauxhalls) use an electronic speedo sender which shares the same 3 pin plug. Have a quick browse in a scrapyard to see if you can find one.
I may have a spare so I'll take a look later to see if I can help you out.
Thanks mate,much appreciated,if you could let me know either way.
Hooray it's your lucky day, found one in my garage. It has a few cm of wire left, enough to solder/crimp connections to. PM me or add me to MSN Messenger (address in my profile).
Mucho thankoOriginally Posted by AW06
Sorted now (thanks iainel)
Admin please close/delete
Originally Posted by Andy
Most cavs and astra have the same plug on the front central locking micro switch plugs. the ones on the back of the locks
