Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
Thread: fitting twin 40's need help with ignition
  1. #11
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    possibly, but ideally you want a 1.4 carbed dizzy as that will definately fit
  2. #12
    Jun 2008
    440
    1.4 8v carb vacumm advance dizzy. ok ill go price one of those up.
  3. #13
    Jun 2008
    440
    engine code 14nz?
    apparenly its a bosh item?
  4. #14
    Senior User tom_beverley's Avatar
    Nov 2002
    Easington, Cleveland Drives: Silver Fabia vRS on satin black Comp TH Mono's Builds: Wide track Nova
    2,407
    14NV I think it is [IIRC C14NZ is the 1.4 SPi], but yes its definately a Bosch item. You will need the coil, leads and amplifier too.
    Probably looking at around £100 for a new dizzy alone. I got mine from Opel Classic Parts [German eBay store].
  5. #15
    Jun 2008
    440
    ok thank you
    the coil and amp, what do these requie wiring wise? are they hard to wire up?
    im fairly good with electric a simple diagram and im sorted,. i wish i had a nova here to copy from
  6. #16
    Jun 2005
    Ilkeston
    13,425
    100 quid for a dizzy alone versus 90quid for megajolt
  7. #17
    Jun 2008
    440
    tell me more about this megajolt,,,,
  8. #18
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Quote Originally Posted by draper
    MJ ends up costing a lot more though....
    Needs TPS, full EDIS system, custom 36-1 trigger crank wheel, full map etc etc....
    Only the initial ecu cost is cheap
    EDIT-If you have a 1600 8v engine(standard cam), then the 1.2/1.3 dizzys wont fit the cam.
    1.4sr (14nv will)
  9. #19
    Jun 2008
    440
    penis to wireing in all that. is the megajolt the diy ecu thing ive seen?
    you have to solder it all together?
    and
    would this coil be ok,?
    http://cgi.ebay.co.uk/NEW-LUCAS-COIL...3286.m14.l1318
    all i need then is a ignition amp, and the dizzy
  10. #20
    Nov 2002
    2,407
    Quote Originally Posted by adam-d
    Nope, wrong engine. Just go to your motorfactors and quote the model [Nova 1.4SR] and engine code [14NV] and they should give you the correct one. I'm not sure but the amplifier may be included with the coil, I just mentioned it so you know there is one.
