im fitting a set of twin 40 carbs to a nova gsi engine.
couple of problems, how do i wire in the coil, ignition module and the 3 pin black plug on the dizzy
the ignition module has 4 pins,
the coil has 2 and the coil lead,
and the plug on the dizzy has 3.
does anyone know what i need to do to make it all work?
i have the nova gsi loom, i dont mind chopping the 3 required plugs out of it, and i dont mind making a bit of loom.
any help appreciated
also where the std inlet was, there is now a hole "vacumm"? that goes throu to the exhaust port. i guess i block this off, but want'd to make sure before i did
