Page 23 of 26 FirstFirst ... 132122232425 ... LastLast
Results 221 to 230 of 251
Thread: Conads turbo Gsi
  1. #221
    Nov 2005
    WREXHAM
    1,891
    Could really do with your help guys as stated in the previous post, here's a more detailed picture, didn't realise how blurred the last ones were
  2. #222
    23,813
    Not a hard fix. Cut out the middle (green bit) Clean all the sides up then put a flat plate in there. On the top (in the boot) cut the metal back so you can see in the chassis leg, as i bet that's rotten too. Then you can work out if you need to remove the end and replace. Then weld a flat plate in from the top over the holes. Joining bottom and top plates.
    Not that bad, ashamed to say i had to do the same in mine. Due to the sunroof drain being blocked.
  3. #223
    Nov 2005
    WREXHAM
    1,891
    Thanks Benn... I knew I could rely on you for a reply. I know where needs cutting and replacing... My problem is getting in there to cut it, I can't get my grinder in there enough to make a neat job.
  4. #224
    User jonn's Avatar
    Dec 2008
    ireland
    1,214
    i use a dremel with small cutting disc. takes a while and a good few discs.
  5. #225
    23,813
    Quote Originally Posted by conad View Post
    Cut what you can out, then grind the rest to 1 remove left overs, 2 clean up for welding.
    Grinder, or a belt sander. One of the best tools i own.
    I made plates up like this... They dont look neat there, but everything with trimed and made nice.
  6. #226
    Nov 2005
    WREXHAM
    1,891
    Quote Originally Posted by jonn View Post
    Cheers guys, I got there in the end, I took the guard off my air cut off tool, made things easier, the rest was threatened with a mahoosive chisel. Made a template with a cheerios box and bobs your uncle.
  7. #227
    User Club Member
    North Wales
    674
    Good work, looks awkward and annoying
  8. #228
    Jun 2009
    Newark
    4,682
    The front end fit is very good for a Nova, I spent hours trying to get mine half as good as that!
  9. #229
    Nov 2005
    WREXHAM
    1,891
    Quote Originally Posted by Novaload_Nick View Post
    Exactly that
    Quote Originally Posted by Balley View Post
    It all seems to fit better than before I changed the panel
  10. #230
    23,813
    Now looking at this, what was the chassis leg like under? As it looks a bit crispy... Unless it's just the pic....
