Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Alternator wiring?
    Nov 1999
    Your wife's bed
    3,760
    Default Alternator wiring?
    What wires colours should i have going to the nova's alternator? The liught is showing on my dash to say its not charging but i recon its wired in right!
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    A blue/white between the light and the alterternator small terminal.
    A thick red from the alternator to the starter motor pos12v terminal/battery
    Oh, a a earth between the alt and engine(that could stop it charging if its not fitted)
    Nov 1999
    Your wife's bed
    3,760
    Hmm it is wired right then, maybe i have ****ed the alternator.
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Get a multimeter on the batt when the engines running.
    Or whereabouts does the batt gauge sit with the engine running(if you gsi clocks fitted)
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    I had the same prob with mine, just disapeared after a while i think. Batt light stayed on and putting a volt meter across it showed it was fine.
    User NovaGuy1400SRi's Avatar
    May 2004
    Fife, Scotland Drives:Nova SRi
    596
    mines the opposite, my alternator doesnt work, but the light doesnt come on, i dont even get the light on when i turn the ignition on, changed the bulb too, got another alternator now though so i should get it swapped over at the weekend and see what happens.
    John.
    Nov 1999
    Your wife's bed
    3,760
    I have been advised the light should be connected to a switched live and then once the 2 vlotages are the same the light goes out.
    OMG! WTF? BBQ :) Lee's Avatar
    Jun 2005
    Newbury
    16,724
    Quote Originally Posted by MAD_Rick
    The light should get its switched feed from the clocks itself iirc.
    You definately have an earth strap between the alt and the head?
    Nov 1999
    Your wife's bed
    3,760
    Quote Originally Posted by Lee
    Yes its charging ok as i can see the battery voltage go up when i start the engine.
    I am not running standard clocks so need to figure out the wiring for the new blub setup.
  10. #10
    Jan 2003
    SOMERSET
    19,510
    Earth the alt adjuster bracket.
