Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Wipers not parking
  1. #21
    Senior User Club Member Novasport's Avatar
    Jan 2004
    Derby, Derbyshire. Drives: Nova Sport, BMW M3, Nova Swing, Peugeot 208
    9,086
    It will be the park switch in the motor, its the only thing it can be. Nothing else knows what position the wipers are in. I assume it must be a common fault on the early Delco motors as they were superceded in 1985 and later ones have to be fitted in place with an adaper harness.
  2. #22
    Concours King Dec16v's Avatar
    Sep 2006
    Surrey
    543
    What a nightmare, and what are the odds of the 2 wiper motors I have both doing the same thing!
    Mind you, I hope not to be using the wipers much
  3. #23
    Club Member Club Member
    Jul 2006
    217
    If anyone wants to prove its the wiper motor at fault around a year ago Vauxhall were doing them for around £ 160 brand new!!!!!
  4. #24
    Dec 2006
    Scarborough
    524
    I've had a look at the wiring section of haynes manual (It's a pass time I usually try to keep hidden). All the wipers mechanisms look the same (electrically at least). Some models have an extra relay but I will try to cover all types in my explanation of operation.
    Here goes, deep breath.
    All motor mechanisms have 5 wires, three are for the motor itself as follows:
    Brown (ground)
    White (motor fast speed)
    Yellow (slow / normal speed)
    Note there is no motor feedback itself, this is done by a sensing switch utilising the following wires:
    Black/Violet (Permanent supply when ignition is on)
    Blue or Green (Permanent supply fed back IF wiper mechanism is not in 'home' postion)
    So when the motor is told to stop either by turning the wiper off or by the timing relay seizing its operation, the returning blue or green wire will be a 12V IF the wipers are not home. If you have a green wire, this means you have a relay fitted, if this relay has stopped its operation (give it a few seconds after using washer) the green wire going to it is connected to a blue wire via a normally closed relay contact. The blue wire of either type of circuit is then fed back to the wiper stalk. The stalk should now, if in the stopped position feed this supply to the yellow (slow) motor wire enabling it to carry on until the sensing switch senses the 'home' position therefore breaking the supply loop.
    So the problem could lie in one of three areas, motor mechanism switch, relay contacts (if fitted) and finally wiper stalk - no great suprise. The way to go about fixing this in a methodical way without replacing all components is by measuring the voltage on the current path that should act to move the wipers down, that is (in order) Black/violet wire to green (if relay fitted) to blue wire to yellow wire. Where the voltage fails to materialise proves which switch / relay contact is at fault.
    Personall speaking I think it will be a worn 'home' position sensing switch - maybe it wasn't the best design on earlier models?
    Iain
  5. #25
    Jan 2008
    Bridgwater, Somerset
    353
    If it doesnt happen all the time then the chances are it a loose connection or a relay mate!
  6. #26
    nova glass whore
    Sep 2007
    norf east
    734
    both mine work fine?? not that int makes any difference cos im blind!!
  7. #27
    Jan 2003
    The toon
    5,265
    Just to update you on this.
    I changed the switch.. No luck
    I changed the relay... No luck
    Today I switch the motor and hey presto they park!
  8. #28
    Sep 2006
    Surrey
    543
    Quote Originally Posted by novacabrio
    Weird.... I changed another motor and it still didn't solve the prob, I must have 2 duff motors
  9. #29
    Mar 2008
    SE London
    4,406
    nice, u got it sorted
