Like that gear linkage, looks solid.
Mintex F6R pads have arrived from Questmead for the 256mm 16V calipers. Group A shafts from Protec should arrive sometime this week aswell.https://uploads.tapatalk-cdn.com/202...0cb3c6d28e.jpg
Tony law Exhaust all finished, all bolted to the car and tucked up out of the way. Skidded around the tank & axle area aswell https://uploads.tapatalk-cdn.com/202...a8de96c440.jpg
https://uploads.tapatalk-cdn.com/202...c394b19001.jpg
Exhaust looks quality :thumb:... and that fuel tank looks like it's carbon fibre :eek:
I don't normally like to ask, but what did the exhaust cost you?
Ahh right... still looks sweet though!
Shame you have to take it off the road so quickly, but if you've had the gearbox off before, it won't take you long to have it put right.
Car is looking good. :thumb:
Nick
My fault for not checking the clutch when I put it in, too worn which was causing it to slip. Got it all out in a hour .https://uploads.tapatalk-cdn.com/202...1cebc7e12b.jpg
https://uploads.tapatalk-cdn.com/202...32c3347c2e.jpg
https://uploads.tapatalk-cdn.com/202...c94718d48e.jpg
Not much I can do as waiting on a new helix clutch being made which I should get in a couple of weeks. Swapped over the release bearing cone that was used on the AP clutch for a standard one with a new bearing
https://uploads.tapatalk-cdn.com/202...8f6f0c7318.jpg
https://uploads.tapatalk-cdn.com/202...e80e387df2.jpg
