Nice installation, I must do similar. If i drive on longer track the discs are blue. :)
Hang the fuck on. You came to Havant and didn't come the 5mins more to see you?
Loving the progress, tanks looks much better sunk down, the brake cooling tube is a great way. That should help alot.
Sorry mate!! Was piss wet through from the rain!!!
Few little things worked out today. Found a wiring diagram online for wipers, I've been having to manually park the wipers which is bloody boring!!
https://uploads.tapatalk-cdn.com/201...8d25f6d4fb.jpg
Made the little loom up this evening and tested it, all works, on fast second speed too!! Will get it all wired in properly tomorrow!!
Joined Craig at a very very wet Castle Coombe on Friday.
For some reason my heated screen refused to de-mist, I think it's screwed!!
No drama, brake ducting borrowed
https://uploads.tapatalk-cdn.com/201...15b1451bdf.jpg
https://uploads.tapatalk-cdn.com/201...e3a397ae89.jpg
Did the job perfectly, de-misted the screen, meant all was not ruined!!
Amazing how much front end grip the Rainsports offered, really felt confident in the car. Few little tickles out of the last corner Camp as it was really slippery with both a Clio and an RX7 smashing into the barrier in a big way in the morning.
Also collected my new windows!!
https://uploads.tapatalk-cdn.com/201...fa7e6c2289.jpg
https://uploads.tapatalk-cdn.com/201...927d15ff7f.jpg
New seals required for the front but I've got a little plan for those. Rears in, looking fresh.
Also decided that my seat was far too high, 9 inch grinder came out, added some new 30x30x3mm box and that went in well, levelled the car up as best as I could and as such the seat rails went in level, just need my weld in inserts to properly keep the seat in place.
https://uploads.tapatalk-cdn.com/201...29e0cfa5d5.jpg
https://uploads.tapatalk-cdn.com/201...2030c7c5e9.jpg
Seats were level before, bout 30mm lower and even further back now too, got to sort something with the steering wheel next, get it lower and closer to me
https://uploads.tapatalk-cdn.com/201...3c3d4b1eea.jpg
New front brake lines to go on, little link to get them away from the wheel as I've had the current ones rub on the inside of the wheel!!! These will be loads better.
Looking very good
Few sneak peaks of what's happening next weekend
https://uploads.tapatalk-cdn.com/201...4434af1a96.jpg
https://uploads.tapatalk-cdn.com/201...e4ff4b8a03.jpg
Need the bigger discs, will swap those out at Euros tomorrow, then get the lines fitted up, might not have the handbrake fitted but will hopefully have it all ready and aligned for Cadwell, worst case Ben has done a good job of getting it straight and square so could run Cadwell without getting it 4 wheel aligned.
Ordered all the cap head bolts and got some lovely SS brake fittings and PVC coated SS Braided lines, will have fun making that this week.
That beam is giving me the horn!
That'll work wonders
Looks like mine. Yours is probably better though if it was made by Ben at Hangar 30.
