After getting my nova on the road it's started to cut out when warm and also kangaroos when driving around 20mph. It's had new plugs leads rotor cap gaskets ect. Any ideas?Cheers :thumb:
Any eml? Check fuel pump?
Eml is next to get wired up I have had to throw car together as need it as my daily as my golf decided to wreck the engine. Fuel pump is new but will check it. Cheers
Car still doing this in low gear. New cts sensor and checked everything inc wiring. Could the box be knackered. ?
Doing my head in this now car not cutting out now but still juddering at low speed and is a annoying me. What could be the cause?
Do these have speed sensors? Sounds like speed sensor
I ain't sure on the gte?? Anyone know?
I assume you've also checked the basics like ignition timing?
Air flow meter? Or a leak after it
Yes ignition timing checked carnt find any leaks.!
