Battery light/not charging issue
Recently have bought a 1.2 Antibes with a few issues (not counting almost terminal tinworm).
The main issue at the moment is the battery isn't charging at all, alternator was swapped for a known good unit and still the same problem.
- The battery light is on at idle but when the car is revved it goes out - you have to rev it harder the more the engine is run.
- The rev counter fluctuates if you put the indicators on or headlights.
- Fuel gauge goes down until you rev it upon which it will return to the right level
- When you switch the car off and take the key out the battery light comes on. flashing the headlights will turn this off.
- No battery light illuminated when ignition is turned to II before cranking.
Any ideas?? I have noticed a wire with a spade end disconnected on the bottom left of the coil as you look at it from the drivers side.
Thanks.
