Any fitted an xe cam sensor on a let before ? If so what cam did you use . Cheers
They use a hall effect sensor in the dizzy don't they? Think they're the same
No good having a dizzy with cop i just need it for fully sequential fueling. Xe with coilpack have a cam sensor but the xe exhaust cam is no good for me
Thathttps://uploads.tapatalk-cdn.com/201...a3a4fb1190.jpg
Sent from my CLT-L29 using Tapatalk
Cant you just tap the hole that used to drive the dizzy and bolt the trigger on? I cant imagine the centre would be different
This is a possibility i have thought about . Im not sure if the dizzy lug hole is in the correct position on the cam for the signal or if the position even makes a difference aslong as a signal is being made ? Its to work with ms3x so id have thought there will be settings somewere to alter the pickup point
Thats how it should look the dimple fits in the dizzy lug hole . Chances are i could probs work it out off that pick and have my cam drilled and threadedhttps://uploads.tapatalk-cdn.com/201...59cc65d1c8.jpg
