After more digging out filler on the pillar it looks like the door has been hit bending the pillar area making the door fit bad. So here are some pics. Anyone scrapping a shell they could cut the area out for me ? Cheers. https://uploads.tapatalk-cdn.com/201...eda4e14072.jpghttps://uploads.tapatalk-cdn.com/201...1e498e7de2.jpg
Sent from my SM-A520F using Tapatalk
Cheers pal. Have you a scrap shell with a good n.s pillar?
Been busy drilling spot welds out. Quite a few I must say. Flitch panel removed. Then came cutting the pillar out.
Inner sill is minty fresh behind as is the rest so all good. On with the repair pillar next weekend also need some gas to weld it on. Will update next week. https://uploads.tapatalk-cdn.com/201...9e8932f07c.jpghttps://uploads.tapatalk-cdn.com/201...087e0441ae.jpghttps://uploads.tapatalk-cdn.com/201...157444d2b7.jpghttps://uploads.tapatalk-cdn.com/201...ae866dcf19.jpghttps://uploads.tapatalk-cdn.com/201...724c23a7e0.jpg
Update. Need some help on this. I've found a other pillar which I have welded in but the problem is the door gap is exactly the same as before. Iam at a loss to what is causing this! Any one shed some light on it. Here is a pic. It's tight at the top and wide as it meets the lower point of the pillar. Also I have a big wing to door gap. https://uploads.tapatalk-cdn.com/201...f8e01463aa.jpg
Yes pal I've even tried a spare door on and it's the same.
Update got new pillar welded in and skimmed up. Got gaps a lot better aswell not 100 per cent but happy now. Next up weld up the flitch panel and finish 2k priming and fit new screen as cracked the hell out of the other one. Also got a fuel leak to sort. https://uploads.tapatalk-cdn.com/201...873ad20aae.jpghttps://uploads.tapatalk-cdn.com/201...ea024a2b7e.jpg
Flitch panel on and seam sealed. Carpet back in will get some more sorted later on. https://uploads.tapatalk-cdn.com/201...e70b7d73a4.jpghttps://uploads.tapatalk-cdn.com/201...e026873362.jpg
