Sweet, custom manifold etc? Do you know of the trooper turbo was off a 3.1 or a 3.0? Or if there is any difference?
I fitted a boost gauge to my 1.7td yesterday. All good and showing 7psi as it should. So fitted the bleed valve and turned the fuel screw up half a turn. Still only 7psi. Now I know that its the extra fuel that will up the boost but should I have seen a slight rise with half a turn on the screw? How many turns have other people turned it to get 1 bar?
Also I haven't done the white ring mod yet as im waiting on a gasket so will this be limiting the boost/fueling enough to not see a change on the boost gauge?
