Few additional pics
https://uploads.tapatalk-cdn.com/201...7bdb765dda.jpg
https://uploads.tapatalk-cdn.com/201...80be371914.jpg
https://uploads.tapatalk-cdn.com/201...513b55a420.jpg
https://uploads.tapatalk-cdn.com/201...0cf8c6efbc.jpg
Nice, very nice.
very nice!
what alternator are you running?
edit: do you have more info on the brake switch you use?
it looks like to be an very small pressure switch?
Yes, they come with a single V pulley as standard. I swapped that for a 4 groove alloy pulley from Brise, as well as a Titanium retaining nut. Total weight of the alternator is about 2.5kg.
Great way to save weight and space, but shop carefully, you definitely are better off with a genuine Nippon Denso item. There are huge numbers of aftermarket copies, and they just aren't of the same quality.
I can give anyone the part number if they want to get one.
In a few twists and turns, using the unit as storage only now, not happy with security for the car down there.
So
https://uploads.tapatalk-cdn.com/201...0d5aab6dfa.jpg
25mm on the walls
https://uploads.tapatalk-cdn.com/201...cfd10c9025.jpg
75mm on the floor
https://uploads.tapatalk-cdn.com/201...9813387e53.jpg
Flooring tiles down, not the best brand but they're good enough
https://uploads.tapatalk-cdn.com/201...03534ee669.jpg
Shelving over the toolbox
https://uploads.tapatalk-cdn.com/201...82761ce888.jpg
25mm up inside the roof too
https://uploads.tapatalk-cdn.com/201...1cad09ce66.jpg
https://uploads.tapatalk-cdn.com/201...89aebddec2.jpg
With the car hard over I can get a metre on the opposite side, the doors will be removable so I just need to figure a way of moving it easily on the rally stands
https://uploads.tapatalk-cdn.com/201...655fdcad9f.jpg
https://uploads.tapatalk-cdn.com/201...826e71decf.jpg
Plenty of work space up in front too
Got the tool box back in there today, using the roof-space as storage, plenty of space up there.
I've got an air conditioner/air source heat pump coming, I can get it to stay at around 12 degrees with a small oil filled rad whilst it's been 1-2 degrees outside.
