Looking good mate .
Looking good mate .
Front legs made up
https://uploads.tapatalk-cdn.com/201...4ca7615e76.jpg
Also decided I wasn’t going to risk alternator clearance despite it clearing on the car it came out of....
So out with the blowtorch and big calibrator
https://uploads.tapatalk-cdn.com/201...228b395bbe.jpghttps://uploads.tapatalk-cdn.com/201...b2f2eab801.jpghttps://uploads.tapatalk-cdn.com/201...d34267125c.jpg re did the weld too, just needs cleaning up, sealing, priming and painting AGAIN.... luckily I wasn’t happy with the finish anyway!
Aim is to get this done this week/weekend, get the front end back on some wheels so I can turn her round, then bring the engine back home and drop it in.
Then it should be a case of wiring/plumbing it all in, fit the gte tank and get her on the road...... if only it was that easy
Primed, sealed, primed and painted, not the best job but I’ll get the bay done properly next time the engines out.
https://uploads.tapatalk-cdn.com/201...7679b32667.jpg
Had some paint left so gave the white grill a blow over, again not the best but better than white or a stock merit grill.
https://uploads.tapatalk-cdn.com/201...99a958926a.jpg
Little update today but a significant one....
Bearings, knuckles and hubs/drive flanges what ever you want to call them, all pressed together.... https://uploads.tapatalk-cdn.com/201...83f21c7275.jpg
Bushes pressed into lower arms and tie bar mounts, all bolted together with ball joints, used existing as they’re fine!
https://uploads.tapatalk-cdn.com/201...9be1c341c2.jpg
All bolted together and shocks on....
https://uploads.tapatalk-cdn.com/201...82d39ef330.jpg everything will get masked off too so I can spray the inner arch with black stone chip too...
And as of 9pm this eve the car is back on all 4 Wheels on the ground ready to turn round..... which means I can jack up the rear and swap the fuel tank over and rear shocks....
but more importantly get the XE dropped in!!!
Not hanging about...
i notice that you said 'next time the engines out'....I said that 20 years ago...lollollol Maybe next year..:cry:
Not hanging about now, it was meant to be done for Bromley Pageant in June 🤣[emoji23]🤣 finally gathering pace getting stuff done, life seemed to get in the way.
I have all the intention of the engine coming out next October, but I’m under no illusions it probably won’t 🤣[emoji23]
Stock tank dropped, ready for GTE tank, and car is facing the right way for the engine to drop in....https://uploads.tapatalk-cdn.com/201...46e35fa84b.jpg
It’s here!!!
https://uploads.tapatalk-cdn.com/201...4f3fc80e3f.jpg
Little update today
Car goes up
https://uploads.tapatalk-cdn.com/201...bd937122d3.jpg
Engine goes under
https://uploads.tapatalk-cdn.com/201...deada223f9.jpg
Car goes down and engine goes up
https://uploads.tapatalk-cdn.com/201...792f73ba73.jpg
Ta-daaaaa
https://uploads.tapatalk-cdn.com/201...cbde4a43a0.jpg
Very happy today, manifold to go on and sort fitting of exhaust.
Al hoses etc to go on, fuel lines to sort, oil change and remove sandwich plate for the old oil cooler, wire it up and get her started
