http://www.pngclub.com/forum/showthr...hlight=diagram
Nice article mate. You say the driverside mount needs lowering, but is this only for 1.0 shells or would I need to do this with my 1.2 spi shell?
Thanks
all shells need it lowering by 1.5 inches.
Anyone? :)
Thanks mateQuote:
Originally Posted by Rob
done a search but cant find anything, im going big block with c18xe soon and im wanting to use cav or similar hubs machined and pressed in nova bearings, this i can sort. The bit i cant remember is which shafts i need can i use cav/calibra etc do i need to shorten them and make a new circlip groove?
iirc you need conversion shafts, its corsas you re groove em on. id look for gte shafts with cav 1.6 innners, fine for that conversion mate
I am in the process of the conversion but useing bike carbs got the manifold and carbs had my dizzy converted (off the 1.2) got a good spark but cant get it to run. I did have it running until the starter broke changed that now but waont fire up any ideas guys?????
earth wire?
