As above anyone know how this is done. I have tried threaded rod with nuts and washers with no joy
Cheers Richard
Cheers Richard
Just done mine with poly bushes. All I did is use plenty of lube and sat the bush inside using a socket the same size hammer in job done.
^^^ same as above plenty of lube and and some good action with your hammer shaft and she will be sorted lol:thumb:
Just saw them in half
That's the problem these are rubber and one piece no hope of hammering them in.
Could have a word with Ratty. He pressed mine out. Also... answer your text!
Wd40 and a vice?
This looks quite a good way of installing bushes:
http://www.suspension.com/blog/how-t...thout-a-press/
MG no need for any of this; angle grind one side off with a cutting disk & push out.
New bush; same 1MM cutting disk cut the middle of the bush creating 2 halves.
10 min cake mode
