http://i1233.photobucket.com/albums/...mporary_23.jpg
Here is the standard vectra cable against the new heavier duty ones, the heavier duty ones have a longer ''middle'' cable, would get this shorter for any more cables made as it would remove the need to make that bracket up at this end and also be closer to the turret at the box side.
http://i1233.photobucket.com/albums/...mporary_13.jpg
So how does it now feel??? I know the cable shift on my Meriva with an M32 has a much better feel that the nova style linkage that my wifes 1.8 Meriva has.
I assume under load with the engine moving around, as the cables are on a fixed point on the gearbox it will make little difference in the ability to select gears . Good job !!
Joff
Now for the bracket at the gearbox side
http://i1233.photobucket.com/albums/...151106_002.jpg
http://i1233.photobucket.com/albums/...151106_003.jpg
http://i1233.photobucket.com/albums/...151106_004.jpg
http://i1233.photobucket.com/albums/...151106_008.jpg
http://i1233.photobucket.com/albums/...151106_011.jpg
http://i1233.photobucket.com/albums/...151106_012.jpg
http://i1233.photobucket.com/albums/...mporary_30.jpg
Final Bracket all strengthened up, on to the car for the 12th time.
http://i1233.photobucket.com/albums/...mporary_31.jpg
