Just an extended drag spoiler pal . To loose that air that usualy gathers around the tailgate area . I fitted it a few years ago with great results . Car was 5mph faster on average with that fitted which is a huge improvement
Bit better pichttps://uploads.tapatalk-cdn.com/201...6974a79f22.jpg
Sent from my EVA-L09 using Tapatalk
Finishing off all the final stuff I wanted to do to the car .
Lobster back welded up now just needs welding onto the intercooler.
Anand got the chute mount welded up and fitted.
Aswell as a few other bits and bobs
https://uploads.tapatalk-cdn.com/201...0b5e00222c.jpghttps://uploads.tapatalk-cdn.com/201...d1bb326a82.jpghttps://uploads.tapatalk-cdn.com/201...d13b0e5336.jpghttps://uploads.tapatalk-cdn.com/201...3523463f24.jpghttps://uploads.tapatalk-cdn.com/201...f2e90d358c.jpghttps://uploads.tapatalk-cdn.com/201...854df2138c.jpg
Awesome stuff mate, looks the part now, subed to your YouTube to see updates.
Thought about a rear diffuser? If not I'd probably least cut the rear bumper upto them holes for less drag.
Cheers for the sub I did same with your channel .Not going for defuser mate just another series of holes offset to these ones . My fuel tank is behind rear bumper so makes it awkward to get a decent size defuser on .
On my old track car I cut it from the exhaust cut out, came up to the flat above the curve, all along the length then curved it back to the outer side of the toe loop opening.
On its way to get tuned pick it up in a weeks time all being wellhttps://uploads.tapatalk-cdn.com/201...4a0bbcd05c.jpg
What sort of power are you expecting?
The motor its self was built for figures around 700hp however the standard inlet and the turbo will restrict it to around 400 . I have a big plenum inlet still to go on and a gtx3582r which I just need a new manifold for so should see figures of 600hp before the season has finished . Still work to do but there is a few events I want to attend hence the reason its getting tuned now
New high flow fuel rail im currently making .
The blank rail was from RnD and a local machine shop has drilled the injector ports and I now just need to cut a bit off the end and weld the An8 fittings and lugs on
Also got a megasquirt 3 with expansion board fitted and 4 bar map sensor / knock light / bluetooth ordered from extra efi
https://uploads.tapatalk-cdn.com/201...57e7775d4e.jpghttps://uploads.tapatalk-cdn.com/201...2d44448ce4.jpghttps://uploads.tapatalk-cdn.com/201...d51b24b3df.jpg
