plugs out & a lot of cranking it over... never refill the lifters with oil when fitting.Quote:
Last one i fitted did the same, standing there thinking what the f......
Well done Edd and Craig for getting it running.
It reminds me of my Merc Sprinter - that wouldn't fire after a rebuild. Checked everything, found a few things, but still wouldn't fire. Then put BIG boost starter on it and it would over that little bit faster, the hydraulic followers obviously primed and it fired up. I was on it for days, had the injector pump off and re-timed it half a dozen times, bled the injectors loads of times.
I've probably say that the dry lifters were most of the problem.
Still, it's done now!! Good stuff.
What he said.Quote:
Originally Posted by mowgli
Did this with mine prior to its first start up.Did it the other day aswell. It had been sat for3months not started, so just as a precaution, king lead off, cranked it then fired her up. Purred like a kitten!
Glad you got it running Edd. Good job!
