Gonna be nice and loud with that pipe...
Cable shifter in now and selector fit straight onto the box . Just ordered cables and the cable brackethttps://uploads.tapatalk-cdn.com/201...38c7146db6.jpg
Sent from my EVA-L09 using Tapatalk
Nice!
Sorted I cant beleve how easy that was to fit and rig up . Now the gears feel perfect and realy precise . Few bits to patch in and all is wellhttps://uploads.tapatalk-cdn.com/201...5bcf44d918.jpghttps://uploads.tapatalk-cdn.com/201...23e85cc6f2.jpg
Looks really good and a worthwhile mod, I wonder if there is a way of doing this on an f13 gearbox.
Yes im sure it would work just the same .
You would need to adapt the cable bracket thats all as the holes wont be in the top of the gearbox but the gearbox bolt to engine one would still line up at the top of the bracket
This is of an f17 1.8 vectra c . As I say though the bracket has 2 holes for bolts that some f13 dont have so a small adapter would need making thats all.
Liking the cables. Im so tempted to go back to a F20 and go change change.
Much better . There is a 3mm 6" x6" plate welded under all of the cage feet aswell on the under side of the car but this will make the whole job alot stronger and will also hold everything in place when I fit my flat floor at the end of next yearhttps://uploads.tapatalk-cdn.com/201...365129c04e.jpghttps://uploads.tapatalk-cdn.com/201...19dc554e90.jpghttps://uploads.tapatalk-cdn.com/201...31cae0fbb2.jpg
