I've heard that to fit a turbo the main general things are steel gasket to higher the compression and other stuff?
If i was ot have a 1.4 8v engine could it be turbo'd?
you fit a thicker steel gasket to lower the compression. or the expensive way is to change thee pistons and rods to lower it. i think the cam needs to be changed because a n/a engine has more valve overlap.
anything can be turbo'd if you got enough money.
look back a few weeks this has been up a thousand times. you should know better
