Started spraying and welding up the cross brace
https://ep1.pinkbike.org/p5pb16294737/p5pb16294737.jpg
Most don’t bother putting in the cross brace again so fair play for going to the effort. Are you going to weld a top in to box it off?
All tacced up :)
https://ep1.pinkbike.org/p5pb16296449/p5pb16296449.jpg
Hydro sat in place
https://ep1.pinkbike.org/p5pb16303282/p5pb16303282.jpg
Petrol tank modifications in progress
https://ep1.pinkbike.org/p5pb16303284/p5pb16303284.jpg
https://ep1.pinkbike.org/p5pb16303286/p5pb16303286.jpg
Sitting nicely under car, working out mounting points for tank sump/guard
https://ep1.pinkbike.org/p5pb16303288/p5pb16303288.jpg
Modifying the cage for better driver seat placement
https://ep1.pinkbike.org/p5pb16334286/p5pb16334286.jpg
https://ep1.pinkbike.org/p5pb16334283/p5pb16334283.jpg
https://ep1.pinkbike.org/p5pb16334284/p5pb16334284.jpg
Started work on the tank guard/ undertray/ flat-ish floor mounts
https://ep1.pinkbike.org/p5pb16348613/p5pb16348613.jpg
Finally tacced in the roof bar to meet MSA regs
https://ep1.pinkbike.org/p5pb16348614/p5pb16348614.jpg
Is the conversion to IRS allowable with an MSA Category 1 logbook? I ask as MSA Bluebook has the following line under rallying..
48.4.1. The suspension must retain the operating principle and utilise the mounting points as provided by the vehicle manufacturer.
I know you've done a lot of work on it, but wouldn't want you to finish fabrication and get caught out is all.
Paul..
Hi Paul from what we've seen this should be ok as it's been done before on novas that have an MSA logbook 1 and harry hockly do it to there swifts and similar.
Under the impression it more means that turret location is not allowed to be altered and similar to prevent things such as inboard setups but will see if can speak to a scrutineer
