By the looks of it, it should work fine. As you will be cutting and welding it to line up pretty much anything will work..
nice one mate, will be giving that ago, what quickshift linkage works with that?
just a quick question iv got a gte will i be able to fit centre consloe in because my elec window switches are mounted here ? pm me withe answers please
The short answer is no.
I guess its feasable, you would need to get the linkage bar set so low that it goes under the upper tunnel frame that the centre consol is bolted to.
This is somthing i was thinking about, Im planning to try and do somthing so it looks factory. Or just make another centre console.
was also wondering if i could use a corsa linkage as iv go a few hangin about is this possible ?
on doing this myself, will post pics up of my results. top guide and really helpful
I'm struggling to find a shifter that'll fit straight in, without using part of the Nova rod. Most other Vauxhalls seem to have a "slide in to the linkage" end of the shifter rod rather than the "slide over" that the Nova needs?!
Yup/\ Hence why ive had to put two pieces and 2 welds in mine
You need to find the one Olly H uses. Looks like it may not have been a cally one, mk2 astra maybe??
Today I checked various years of Corsa Bs, mk3 Astras, Cavaliers, Vectras and a Calibra and they all looked wrong at the linkage end.
