50L compressor
Spec below. Bought recently to paint the underside of the car and cavity wax but the garage are doing it now. Cost 129 quid will sell for 80 Ono. Is in Hamilton
Trueshopping Yucatan Heavy Duty Air Compressor 50L 2.5HP 7.2CFM 230v
This fully automatic Trueshopping Air Compressor includes a powerful 2.5HP induction motor, which operates from a 13amp supply. Producing 202L/min of air displacement, this compressor brings a totally different dimension to the way you tackle projects without the use of electronic or manual power tools.
The adjustable outlet pressure from the large 50 litre capacity air receiver makes this machine one of the very best performing in the market for its class
The trueshopping Air Compressor is hand built by our expert engineers. This means that it has been built and manufactured to the very highest standards of quality possible. The compressor will operate scores of air tools such as spray guns, nailers, air drills, staplers, die grinders, chisels, impact wrenches, ratchets - the list is endless.
Technical Specification
Air displacement: 202L/min
Motor: 2.5HP, 230V
7.2CFM
Air receiver: 50 litre
Heavy duty oil lubricated pump
Fully automatic control
Fitted with fully adjustable air outlet pressure regulator
2 Air outlets
Working pressure: 6-8bar
RPM: 2800
Dimensions (L) 720mm x (W) 420mm x (H) 720mm
Weight: 32Kg
John have you mentioned ths to Iain (NOVA_SPORT) he was goin to buy one today at machine mart.
David
Cheers bud, will send John a txt just now
Cool, got his txt. Cheers
