With all this isolation going on it would be rude not to do a few jobs to the nova. I have recently moved to a new workshop and I’m in the process of moving my nova stuff over there.
The last time I did any work on the gsi was last year. I removed the carb fuel tank and sourced a gte/gsi one and have painted that ready to go on. But the more worrying things I have found are a few patches of dreaded rust! Hats off to Upol as it hid the rust in the front wheel arches very well! I’ve also found some rot in the offside rear inner arch near the fuel filler. So time to get the welder out!
https://uploads.tapatalk-cdn.com/202...13f6524f0c.jpg
https://uploads.tapatalk-cdn.com/202...fda4a31d7b.jpg
Hope to get stuck in again soon!
Cars now moved to my new workshop, started stripping it out. I was surprised how bad it was. The body repairs I’ve found that must have been done a long long while ago were done to a very average standard!
https://uploads.tapatalk-cdn.com/202...588853bd3e.jpg
I’ve found so much filler on what I thought was a pretty sold shell. It’s going to be a full strip down now.
https://uploads.tapatalk-cdn.com/202...493768e292.jpg
Nearside rear arch is the better of the two and hasn’t been replaced before. The inner arch has rotted away. I suspect due to having the arch lips rolled a long while ago.
https://uploads.tapatalk-cdn.com/202...c74a8a71ae.jpg
Uncovered this on the offside arch. The panel has been spotted on over the top of the old rusty panel. There was around 10mm of filler in places across the 1/4 to blend it all in. I always thought the arches looked a bit wider than other novas I had seen.
https://uploads.tapatalk-cdn.com/202...5182f37912.jpg
The inner arch isn’t good. I’ve got all the arch panels but will have to fabricate some in-between bits to make everything fit.
https://uploads.tapatalk-cdn.com/202...bb77b41ea9.jpg
Just showing the thickness of filler!
https://uploads.tapatalk-cdn.com/202...eefa9e625b.jpg
Old repair uncovered.
https://uploads.tapatalk-cdn.com/202...03b3595a32.jpg
Starting to cut the rot out. My first time doing anything like this so a bit of a learning curve!
https://uploads.tapatalk-cdn.com/202...b21fb9fce3.jpg
Too late now! Next on the list is to chop out the inner arch back to decent metal.
Looks for the best - can't be leaving stuff that isn't right!
