Hi,
Has anyone managed to find a light/good option for front brakes under 13 inch wheels?
All the wilwood kits seem to cater for 256mm kits and minimum 14 inch wheels which is of no interest to me.
Any ideas anyone?
Regards
Phil
Hi,
Any ideas anyone?
Regards
Phil
236mm vented discs with ate calipers, Corsa spec...........
It is what I run on my Nova Sport/SR
I'm putting Wilwood Dynalites on a corsa 240x20mm disc under 13's, but I'm getting an engineer to make up some brackets for them and they'll only go under Revolution RFXs.
Otherwise it looks like 236 vents are the only other option
No need to vented discs as it is a hillclimb car, and wanted to try and find a lighter caliper option really as the standard items weigh a ton.
Sounds like buying a universal wilwood and making a bracket to mount it is the best bet.
Spedeworth Fabrications may have an option.
Why didn't you say it was for hill climb car...........Look here, fill you boots ;)
http://www.pngclub.com/forum/showthr...ova-Sprint-Car
Compbrake do a nice small 4 pot caliper and bracket for a nova ,I got 275 mm behind my 13 inch split rim
