*HOW TO* c20xe R1 bike carbs
i thought this information might be useful for anyone thinking about fitting bike carbs.
>http://www.totalvauxhall.co.uk/files...BIKECARBS1.pdf<
megajolt setup
http://trigger-wheels.com/store/contents/en-uk/d34.html
http://www.autosportlabs.net/Main_Page
here is some pictures and information for R1 carbs that i put onto my c20xe
this is what the carbs look like the fuel inlet is in the middle underneath the carbs.
http://i421.photobucket.com/albums/p...Picture039.jpg
the best fuel pump to use is the r1 pump, it has a built in regulator. when you are wiring in the pump
make sure you dont mix up the wires because the pump will burn out! the earth is the black wire.
http://i421.photobucket.com/albums/p...Picture038.jpg
you will need to get a manifold made, these can be got off boggs brothers, i made my own manifold
http://i421.photobucket.com/albums/p...nny057/122.jpg
http://i421.photobucket.com/albums/p...7/SAM_0795.jpg
you will need a altanator adjusting bracket, i made my own one
http://i421.photobucket.com/albums/p...7/SAM_0799.jpg
the main jets need to be drilled out to 1.8mm for a c20xe these are the middle jets.
http://i421.photobucket.com/albums/p...7/SAM_0804.jpg
http://i421.photobucket.com/albums/p...7/SAM_0814.jpg
for the ignition set up you can use a mk2 cavalier ignition set up or megajolt setup which is what i used.
http://i421.photobucket.com/albums/p...cture026-1.jpg
wiring diagram
http://i421.photobucket.com/albums/p...eWiring1-1.jpg
if you use megajolt you will have to move the new coil up so the plug leads will reach. i modified the old one
http://i421.photobucket.com/albums/p...cture033-1.jpg
to connect the carbs to the manifold i used 42mm water pipe and jubliee clips
http://i421.photobucket.com/albums/p...7/SAM_0793.jpg
http://i421.photobucket.com/albums/p...7/SAM_0792.jpg
all fitted
http://i421.photobucket.com/albums/p...7/SAM_0794.jpg
this is a grate help mate thanks just got one or two questions
whats the reason youve linked each port on the manifold is this a must cheerz :)
