Im back again, I need help with the aerial on the front wing. I want to remove this aerial.
What is the best way to do this? Could you explain how to do it please??
Cheers guys, Chris
Cheers guys, Chris
The best way would be to weld a plate over the back of the hole, fill and smothe the hole and then respray, the area or the whole wing. You could just fit a platic grommet in the whole and paint it body colour?
Look under in the wheel arcg for a little plate that's screwed on, the aerial will come out through it, once you've disconnected from the stereo, then go to vauxhall and ask for a corsa grommet, it fits
This is a bit extreme, but you could get a new wing, that dosn't have a hole in it lol! I'm not sure if new panels come with the holw drilled or not though. Just a thought!
The new wing is a good idea you could take it ot a paint shop to be sprayed first and it will just bolt on when you are ready.
new wings don't have holes for the indicators or aerial
