Any info on the part numbers for a c20let (pot type) late flywheel clutch .
Cheers
Cheers
Anyone??
I believe this is the LUK part number.. 623097200
Hth
Thanks pal
Is there different types ? I ordered a luk clutch and the centre bore is to big and wrong splines for the f20 spigot shaft.
I'm guessing the big centre bore is for f28 and a smaller one would do the f20.
I'll check my part number tomorrow
Yea the F28 shaft is alot biger than the F20.
Yes pal I think its 22 spline you need for f20 or do like I did and just ordered a c20xe clutch . Although I did order a cg motorsport paddle clutch . I nearly fell into the trap of buying a let clutch aswell forgetting all about the f28 being a different shaft
