*HOW TO* remove body panels
as there is no bodywork section i'll post this here
firstly this is a rough guide and is by no means a full how to,
first youll need the wing off, suspension off, front bumper off, headlight and indictor out, washer bottle off, header tank off, coil off etc etc then get a drill with a good spot weld drill and drill out all the spot welds i have marked in yellow where i found most of the welds and green where there is some seam welds to be ground out, i have not got a pic of removing the headlight panel, its only 4 welds iirc and now some pics
its worth noting im removing these panels to reuse in another shell so no " id just use a grinder" comments
INDEX
n/s inner wing removal......page 1
upper firewall removal.......page 2
scuttle panel.......................page 2
o/s engine mount...............page 3
seat support bar.................page 3
o/s inner wing....................page 3
n/s chassis leg...................page 3 ( removed in one full lenght )
o/s chassis leg...................page 4 ( removed from bulkhead forward )
quick guide on how to find welds hidded by sealer ..page 4
n/s rear chassis leg removal......page 7
o/s rear chassis leg removal.......page 7
http://i790.photobucket.com/albums/y...P6120002-1.jpg
http://i790.photobucket.com/albums/y...P6120001-1.jpg
http://i790.photobucket.com/albums/y...P6120003-1.jpg
http://i790.photobucket.com/albums/y...l/P8250037.jpg
http://i790.photobucket.com/albums/y...l/P8250034.jpg
http://i790.photobucket.com/albums/y...P6120008-1.jpg
http://i790.photobucket.com/albums/y...l/P6120007.jpg
