refit fit them in the same way.Quote:
You may have to drill down the hole and through the plate you've welded on. Remember to ignore my pic on the 1st page as I put mine on upside down! :roll: There meant to g underneath the crossmember not on top.Quote:
+1.Quote:
Originally Posted by Adam
welding ym engine bay this weekend and putting in my plating kit, how far should i beat it in or cut it so ihave clearance for a redtop 16v?
a good few cm's
wont this failan mot is they spot a huge crease in the panel next to the engine?
not if you do a neat job
No, creases in the chassis dont come in to an mot.(no matter how untidy it is) And with the engine in place you wont see it.
Would it be better to seam weld around the plates? or just stitch them in?
seam will be fine. you want to add strength but not make the shell too rigid. its designed too have some flex.
