nova breaking
well my circumstances have changed and i really dont have the time to work on the car right now and could do with the cash for my new house
the whole car will be for sale so anything you need just gimme an email at rosselliott99@aol.com as im not online that much at the moment but get emails to my phone
ill add more stuff later
£130
R1 carbs jetted for a 2.0 with original rubbers, will also come with mk2 choke cable and nova throttle cable all modified so plug and play really
£200
megajolt ecu and pre-made loom, this was bought from tom reid and the loom was made by prey, you will receive the ecu, loom, and sensors the loom was made to fit a 2.0 engine (length not plugs) but can be used on any engine you just need to make up a crank sensor bracket and purchase a trigger wheel
£80
magnex stainless 2" system, it has been chopped up a bit as it was originally for a mk2 but i cut the tailpipe off and turned it then re welded it, it also has the front box cut out due to catching it when putting it on a pick up, has a 2" flexi welded on the front to join the manifold but can be cut off
£25
OMP front strut brace, has been repainted yellow, couple marks on it
engine stand £20
the shell is for sale, it was resprayed about a year ago with new sills fitted, its had rear arches done at some point, 2 mint doors were fitted but now 1 has a small dent in it from a wheely bin it needs a bit welding on the rear chassis leg, a small bit on the boot floor where the grommet is and the nearside outrigger welded too
its had a hockleys strenghtening kit welded in stitch welded turrets and legs
the price of the shell will depend what you want with it so please contact me and we'll sort something out
like i said please email me at rosselliott99@aol.com, prices may be negotiable
also have v6 brake setup plenty life left in pads, slight marks on back of the disks where someone has hammered them to get them off dosnt affect them though, comes with spiggot rings too £100 posted
nova 2.0 conversion mounts x2 £35
22 spline shafts with both outer cv's but only 1 inner as it came apart when removing £65
front and rear GTE smooth bumpers £80
click my project thread in my link for pics
Hey dude you wouldn't have any interior for sale ?
only corsa sport interior welded to nova subframes
Ok thanks for letting me know :)
Any pictures of the R1 setup? everything needed to run? Very interested if their for a C20XE :thumb:
ill get some pics tomorrow for you, everything is there apart from the inlet manifold
Does it need Stand alone management to run them?
nope, you can run it using a mk2 cav 1.6 dizzy and coil etc
i do have a megajolt setup for sale too
drivers door and wheels
Intrestd in drivers door and wheels were in country are you?
