What car did the internal shifter come from? Ive been trying to find a cav/calibra one but no luck yet. There are others such as corsa but not sure if they will work.
Good work on the mods :-)
Loving the work. Question though, where did you get your Spigot rings from?
So I have been busy once again.
Since my engine has been on solid mounts the gear linkage has caught the steering rack going into 5th gear. This was making it very hard to select in anger. Not good for 1/4 mile times!
I looked into this and decided my best solution was to shorten my linkage by 3mm.
Out came the grinder and welder again.
https://uploads.tapatalk-cdn.com/201...a8fa2b2a25.jpg
https://uploads.tapatalk-cdn.com/201...1db4b6f11f.jpg
I got it back on and set it up, perfect!
Next job was to try and improve steering feel at speed. A Corsa B steering UJ was ordered. Massive difference between the two!
https://uploads.tapatalk-cdn.com/201...58d777cd8d.jpg
Chop!
https://uploads.tapatalk-cdn.com/201...58c2efb83e.jpg
https://uploads.tapatalk-cdn.com/201...4243992e4c.jpg
https://uploads.tapatalk-cdn.com/201...0fb404538a.jpg
And welded together. Exactly the same length centre to centre!
https://uploads.tapatalk-cdn.com/201...08e049be04.jpg
Painted.
https://uploads.tapatalk-cdn.com/201...19f02a6105.jpg
https://uploads.tapatalk-cdn.com/201...b848ef9802.jpg
It seems to help with feel if nothing else. Notice the new exhaust switch? Haha
https://uploads.tapatalk-cdn.com/201...3369cdab8f.jpg
Next up was the gearbox, I wanted to ditch the WR 5th gear in favour of a standard set up. So while doing this I fitted new seals and gaskets.
https://uploads.tapatalk-cdn.com/201...5d856095ad.jpg
https://uploads.tapatalk-cdn.com/201...00ef7a6665.jpg
https://uploads.tapatalk-cdn.com/201...5166fc0418.jpg
https://uploads.tapatalk-cdn.com/201...cae010dfa6.jpg
https://uploads.tapatalk-cdn.com/201...8e411cf16e.jpg
Old V New
https://uploads.tapatalk-cdn.com/201...37e871cd85.jpg
And back together. Not the best job but needed doing.
https://uploads.tapatalk-cdn.com/201...a9880fe363.jpg
I then fitted this!
https://uploads.tapatalk-cdn.com/201...71fed93e1f.jpg
https://uploads.tapatalk-cdn.com/201...0f94cb05e6.jpg
And did this!
https://uploads.tapatalk-cdn.com/201...3f737193b9.jpg
Oops..
A little trip to my Dads
https://uploads.tapatalk-cdn.com/201...d06b053e07.jpg
Machined to an interference fit,
https://uploads.tapatalk-cdn.com/201...1536b12589.jpg
And pressed together making it exactly 416mm long. Perfect!
https://uploads.tapatalk-cdn.com/201...82882fcb8d.jpg
Out came the welder again. Plug and seem welded, I can't see this going anywhere.
https://uploads.tapatalk-cdn.com/201...a88722808a.jpg
Built back up.
https://uploads.tapatalk-cdn.com/201...49452e2ba9.jpg
Refitted and tested.
Gears feel loads better now, steering is nice and direct and best of all it drives so much better. You can accelerate hard now without massive amounts of torque steer pulling you all over the road. Very happy with the overall results.
https://uploads.tapatalk-cdn.com/201...3d96e39905.jpg
Nice work pal love it.
