Good stuff, seems a good solution. Annoyingly there are ABS sensors in the Corsa B SRi disc rear hubs I am using, but some numpty (i.e. me) cut the wires off flush during installation.
So I re-adjusted my oil cooler to clear the radiator and my grille no longer fitted. Figured now is a good time to get a new grille on it. @total_vauxhall on here was kind enough to provide and gave a great tip to create an even quicker front end removal... M8 tap ran down the plastic pegs
http://iainel.co.uk/images/forums/NovaWIP2b/496.JPG
And it magically bolts to the bumper
http://iainel.co.uk/images/forums/NovaWIP2b/497.JPG
It's a bit floppy but it happily sits where it should without any additional fittings
http://iainel.co.uk/images/forums/NovaWIP2b/498.JPG
2k primed and painted it up in the garden
http://iainel.co.uk/images/forums/NovaWIP2b/499.JPG
Halfords finest mesh to provide the clearance required on the oil cooler
http://iainel.co.uk/images/forums/NovaWIP2b/500.JPG
Bish bash bosh all comes off in 10 seconds on four R-clips
http://iainel.co.uk/images/forums/NovaWIP2b/501.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/502.JPG
:thumb:spot on job mate . Glad that little trick worked for ya
Looks great :) going to do something similar this week
I don't like this
totes stealing that
Looks just like the Astra mk2 front bumper now with built-in grill, but as usual on a Nova it's a darn faff :( Good work sir.
So I've installed some Sabelt 6 point harnesses this weekend. However I've never liked the interference between the lap belt buckles and the seat holes, so I've moved all the mounting points backwards. Loads better.
Sills were the harder ones, I prepped some spreader plates and found a suitable size holesaw to allow me to sink the nuts into the sills flush. Crotch straps were a simple case of drilling and fitting spreader plates in the correct location.
http://iainel.co.uk/images/forums/NovaWIP2b/503.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/504.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/505.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/506.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/507.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/508.JPG
Tunnel eye bolts were moved back a few inches too
http://iainel.co.uk/images/forums/NovaWIP2b/509.JPG
Can see the improved clearance of the adjusters here, perfec'
http://iainel.co.uk/images/forums/NovaWIP2b/510.JPG
Loads better than the old mounting points
Get this diary updated you slacker as you have interesting stuff to add!!! If you don't all post a pic of my sexy vapour blasted high compression Omega pistons, you have been warned ;)
