Johnny A is his name...
Filler is nicely done, mines there too. Really like the motorbike pop out cap. Where is that from? Hate having to use a key on mine...
How much paint do you get for 35 quid?
Next step after rust repair was to start strengthening the shell.
https://scontent-lhr3-1.xx.fbcdn.net...89&oe=568EBE70
https://scontent-lhr3-1.xx.fbcdn.net...f1&oe=5695538C
https://scontent-lhr3-1.xx.fbcdn.net...cf&oe=56897D2D
https://scontent-lhr3-1.xx.fbcdn.net...12&oe=5685B607
https://scontent-lhr3-1.xx.fbcdn.net...e0&oe=5694D19B
https://scontent-lhr3-1.xx.fbcdn.net...d1&oe=56CBDDB6
https://scontent-lhr3-1.xx.fbcdn.net...c8&oe=56879DEC
https://scontent-lhr3-1.xx.fbcdn.net...b8&oe=56953205
Also going to be using a corsa b brake set up so cut out the thin sheet above the pedals and added in a piece of 4mm plate.
https://fbcdn-sphotos-c-a.akamaihd.n...f625aca320786a
https://scontent-lhr3-1.xx.fbcdn.net...d3&oe=56CCEC99
Fits and clears the bonnet. Still have the pedal set up to finish off.
Although i dont think its required when running a small block, i decided to notch the chassis leg in case i ever go for a bigger engine.
https://scontent-lhr3-1.xx.fbcdn.net...01&oe=56918B7C
Pleased with how it came out. i Copied Count vauxalot for this one and again on the brake pedal set up (no pics yet).
I then cut away and re seemed the inner arch so i can remove the gear set without removing the box. Will make it a lot quicker when changing final drive and pinion gears.
https://scontent-lhr3-1.xx.fbcdn.net...25&oe=5696CAFA
Spot on, all the proper mods to future proof it. Enjoying your work.
Next up was the footings and strengthening plates for the roll cage, all 4mm plate.
https://scontent-lhr3-1.xx.fbcdn.net...e4&oe=569933AD
https://scontent-lhr3-1.xx.fbcdn.net...3c&oe=569BB5B8
https://fbcdn-sphotos-f-a.akamaihd.n...696ac0390fd7e5
https://scontent-lhr3-1.xx.fbcdn.net...2c&oe=5697209F
https://scontent-lhr3-1.xx.fbcdn.net...0a&oe=568E7EF4
Also went for a rear strut brace out of 38mm CDS, same size as my roll cage. Added the eyelets for harnesses and stitched around the turrets.
https://scontent-lhr3-1.xx.fbcdn.net...5e&oe=5692690F
https://scontent-lhr3-1.xx.fbcdn.net...1f&oe=5696BD2B
https://scontent-lhr3-1.xx.fbcdn.net...6f&oe=568DB5C6
Then the spreader plates for the rest of the harness mounting points.
https://scontent-lhr3-1.xx.fbcdn.net...69&oe=5693884B
https://scontent-lhr3-1.xx.fbcdn.net...0a&oe=56D37009
https://scontent-lhr3-1.xx.fbcdn.net...28&oe=56CDE9AF
https://scontent-lhr3-1.xx.fbcdn.net...93&oe=568BE7EE
