A vac leak would usualy cause a judder lower down the revs
Will give it another check cheers.
No vac hoses off the manifold?
I did check them but will do again to rule them out.
Check the one way valve thing as well on the pipe to the servo . Mine started passing air through and i noticed the car drove fine after i had pressed the brake . Was a long 200 mile drive home dabbing the brake ever couple of minutes but it made it lol
Will do cheers
Still doing this. I've checked all vac pipes the inlet pipe the one way valve. Any other ideas??
The engine starts fine idles fine from cold one up to temp idle drops to low and cuts out. It will continue to start but then cut out when hot. One cooled a little it's fine and idles normaly. Any ideas ??
Bit of a bodge but a mate used to have to do this with his m5 . When its hot and it cuts out try tipping ice cold water all over the cts until the area is cool if it fires up n runs its a problem there .
Lol will try it. I've fitted a new genuine cts sensor no change. It's annoying me to say the least.
