My omex 600 is not picking up any signal from the brand new crank sensor I have fitted . Is there diffrent kinds ?
And is the crank wheel 60-2?
I'm sure it's 60-2 and was it an eBay special crank sensor or a bosch one?
I think its just an ebay one mate I cant quite remember il have to check it
I have also been reading that the metal type work better with aftermarket ecu's is this correct?
I have a genuine one pal if you need one.
How much mate?
£10 posted.
Sorted pm paypal mate
Tested all the ones I have here I have a metal one but its to long however wave a spanner infront of it and get a good reading .
Then I have the old one out of the motor but the wires were chopped . It soldered them back together and same again tested with multi meter set to 200m I get a reading around 110.0 when ever I wave metal infront of it .
Then I did the same test with the brand new one I bought and I dont get any signal what so ever . So all I can put it down to is its a dodgy sensor
Yes mate, the eBay ones are useless, due to the lack of good bosch ones left a lot of high end engines just run external trigger wheels now
