C20xe not starting suspect wiring. Anyone got a clue?
Hi any help/advice highly appreciated. To cut a long storey short I purchased a Corsa c20xe a week ago purely with the intent of butchering it to do a conversion on one of my novas. Heard it fire but it then cut out so I assumed it would need a service as been stood for a few years. For the past week I have been trying to get it to fire with no luck. Fpr works, it's got spark there's pressure in the fuel rail. The injectors have a constant live and constant ground. Can't work out why there's a constant live to the injectors. I'm unsure it's supposed to be this way and the ecu cuts it out as and when. Or is the ecu knackered. When I unplug the fpr the injectors loose there constant live as they should but the constant negative stays at the injectors. And only goes when I u plug the ecu. Any ideas where I'm going wrong. Or things I havn't checked
