How did you do your wiring for the MOT dash lights?
Liking the upgrades.
Very interesting about the dash lights. Somethings i've been thinking of.
Onto the exciting updates, leading to my first test drive in months today.
Gearbox, I'm now using a Quaife SCCR 4.2 with Quaife ATB diff. It came with the short option fifth gear, so I've swapped in the middle option.
Unexciting looking box:
http://iainel.co.uk/images/forums/NovaWIP2b/527.JPG
Removed fifth:
http://iainel.co.uk/images/forums/NovaWIP2b/528.JPG
Shiny new one:
http://iainel.co.uk/images/forums/NovaWIP2b/529.JPG
Onto the engine, I'm using the one from Houses red shell. Bottom end is 86.5mm with standard recently rebuilt crank/rods. However I wanted to use some bits off mine, namely the oil pump, pickup and cams. Both out for surgery:
http://iainel.co.uk/images/forums/NovaWIP2b/530.JPG
Now there was a slight issue, when the car came to me it was running on 3 cylinders. Turns out a snapped valve spring cap resulted it holding the valve open. Eek.
Head off for inspection:
http://iainel.co.uk/images/forums/NovaWIP2b/531.JPG
Intake ports look nice, think it's worked a little bit:
http://iainel.co.uk/images/forums/NovaWIP2b/532.JPG
New stem seals:
http://iainel.co.uk/images/forums/NovaWIP2b/533.JPG
And cleaned valves and seats:
http://iainel.co.uk/images/forums/NovaWIP2b/534.JPG
On and fitted with Kent AST1612 cams:
http://iainel.co.uk/images/forums/NovaWIP2b/535.JPG
Sump required fettling, my modified one bottom and new one on top received the same treatment:
http://iainel.co.uk/images/forums/NovaWIP2b/536.JPG
Also made a little speed sensor, trying to use the middle CV as a speed sensor:
http://iainel.co.uk/images/forums/NovaWIP2b/537.JPG
Finished and painted:
http://iainel.co.uk/images/forums/NovaWIP2b/538.JPG
Onto the fueling side of things... The carbs are gone. So I've fitted an in-tank Walbro 255 pump to go with my SPI tank, very neat solution:
http://iainel.co.uk/images/forums/NovaWIP2b/539.JPG
Finished pump:
http://iainel.co.uk/images/forums/NovaWIP2b/540.JPG
Fuel system is all AN fittings from the push-fit pump and fuel return on the tank side, with filter in the original location:
http://iainel.co.uk/images/forums/NovaWIP2b/541.JPG
And internal braided lines:
http://iainel.co.uk/images/forums/NovaWIP2b/544.JPG
http://iainel.co.uk/images/forums/NovaWIP2b/545.JPG
Onto the bay side of things, the horn got relocated behind the wing for more space:
http://iainel.co.uk/images/forums/NovaWIP2b/542.JPG
And the FPR and new Mocal catch tank mounted on the strut brace:
http://iainel.co.uk/images/forums/NovaWIP2b/543.JPG
Now onto some more juicy stuff robbed from Houses shell. Jenvey DTH throttle bodies with carbon trumpets:
http://iainel.co.uk/images/forums/NovaWIP2b/546.JPG
Bish bash bosh:
http://iainel.co.uk/images/forums/NovaWIP2b/547.JPG
Throttle cable sorted thanks to a handy kit from Venhill:
http://iainel.co.uk/images/forums/NovaWIP2b/548.JPG
And she runs:
http://iainel.co.uk/images/forums/NovaWIP2b/549.JPG
Finished engine bay, looking good:
http://iainel.co.uk/images/forums/NovaWIP2b/550.JPG
I'm also using the full Powerflow stainless sytem from Houses shell, although it's built for a mk1. Undecided whether I'm going to redo the tailpipe or not:
http://iainel.co.uk/images/forums/NovaWIP2b/551.JPG
First daylight in months and months:
http://iainel.co.uk/images/forums/NovaWIP2b/552.JPG
Looking great! :d :thumb:
Poor old House you stole all his parts
Nice looking machine . Ps i think the tailpipe looks great as it is
Loving that! Tb's are a great add on.
