C20xe parts lots of forged 86p pistons machined pockets
3x sets early Mable forged 86p pistons with machined valve pockets for big cams 120 a set complete with pins
20xe early mk2 astra complete loom ecu in cut all plugs intact. I rips etc vgc 150
complete rebuild xe Xe new rings new shells new gaskets all valves recut new stem seals all payne gaskets and glyco shells Mable rings not even run bare engine block head 600 can included coil pack our dizzy set up 750 with everything to run
exhaust manifolds 50 each
cyclinder head freshly skimmed all valves ground new seal chemically cleaned 200
afm 30 each
X4 brand new rubber donuts (afm to throttle body) genuine gm in packets un opened 30 each
knock sensors 10 each
rods 40 a set
flat flywheel 80
c20xe to f13 flywheel 50
f18wr box from cav td 100
f16boxes 80 each
complete bottom end rebuilt forged pistons new ring shells gaskets etc 350
lots more parts just ask having big clear out also 8v engines 1.2 1.4 2.0
