How To 5 Stud your Nova.
A quick quide to 5 studding your Nova.
What you'll need.
2x front Cav or Vectra front hubs.(Vectra ones are easier)
2x new Nova front wheel bearing kits.
Big block convo shafts with big block (cav) outer and inner cv joints.
Cav v6 or Vectra 5 stud rear hubs. (you can't use Calibra rear hubs)
With calipars.
5 stud wheels.
Brakes to suit as 4 stud discs wont bolt to the hub.
A Cav mk2 short hand brake cable (to run the drivers side brake) I use the middle length cable.
You might need to make new brake lines for the beam. Or you can try and bend yours.
So take your 5stud hub. Shown here,
http://img.photobucket.com/albums/v3...eslathing7.jpg
This is the bit you machine, down to this size 34mm OD (which is Nova bearing size)
http://i6.photobucket.com/albums/y23...eslathing4.jpg
http://img.photobucket.com/albums/v3...Lathing031.jpg
http://img.photobucket.com/albums/v3...Lathing018.jpg
Making sure you keep a good radius on the bottom for the bearing to run on.
http://i6.photobucket.com/albums/y23...n/IMG_8850.jpg
If you use Cav hubs you might have this extra lump on them, if you do you'll need to take this down too, as a 288 disc one fit over it.
http://i6.photobucket.com/albums/y23...n/IMG_8835.jpg
Press the hub in to a new Nova front wheel bearing. Then press that all in to your hub and fit circlips.
http://img.photobucket.com/albums/v3...Lathing026.jpg
http://img.photobucket.com/albums/v3...Lathing044.jpg
http://img.photobucket.com/albums/v3...teslathing.jpg
Now a 256 disc wont bolt to use new hub as they are the wrong PCD, so either dont bolt them up or upgrade your brakes (i would) at the same time.
Rears.
Your beam will be converting to run discs for the first part. Once that is done, you need either Cav v6(non abs if you can find, if not you need to make sure the abs ring fits the hole in your beam, if not open the hole up or get the abs ring machined off like here,
http://img.photobucket.com/albums/v3...ubmaching2.jpg
http://img.photobucket.com/albums/v3...ubmaching4.jpg
http://img.photobucket.com/albums/v3...ubmaching3.jpg
or Vectra rear hubs.
http://img.photobucket.com/albums/v3...decupdate9.jpg
Once bolted on, you'll need a Cav mk2 short hand brake cable to fit the drivers side and a Nova long for the pass side.
You may need to remake your brake lines on the beam, as the calipar is in a different place to the Nova hub and cylinder, you might get away with bending it tho.
After bleeding your brakes you can fit your new wheels and enjoy.
Also if you want to 5 stud the front with a small block engine and standard shafts then you can use meriva hub flanges, these fit directly into the nova bearings. You would then fit brakes to suit.
Part number for these are 13211373.
Really? I didn't think any 5 stud hubs where small block...
Small Block 5 stud
Yeh, tried and tested on my TD fella :thumb:
http://i102.photobucket.com/albums/m...011/5stud2.jpg
http://i102.photobucket.com/albums/m...011/5stud6.jpg
http://i102.photobucket.com/albums/m...1-05154825.jpg
http://i102.photobucket.com/albums/m...011/5stud1.jpg
If you use the part number given its a straight swap with the nova 4 stud flange as all the dimensions are the same.
So aquire the above mentioned meriva hub flanges (part number 13211373) and 2 new nova front wheel bearings for your model as there is 2 differning sizes.
Press the old nova flange and bearings out the nova hub carrier, press in new bearings and then press in the meriva hub flange. Job Done!
Ah good work, wish i had known that when i first did it. Couldn't find anything that matched.
Yeh took a bit of research and annoying Mr parts man for some measurements but got a result in the end!
