Anyone with EPC access?
Hi all,
I was hoping someone on here will have access to EPC as I need some definitive identification of part numbers for some cam shafts I have. Tried the online Opel/Vaux catalogues but none identify them. Only been able to get some info from various forum posts, but some info is speculative.
I have the following:
90 423 010 (00 388 59 192) - assume this to be LET standard cam (inlet)
90 423 011 - as above (exhaust)
90 322 027 (00 38859 022) - unsure if it is XE or LET (inlet)
2091358 - I have two of these which are stamped the same but one is long and one is short (dizzy exhaust and inlet) I believe these are XE cams.
Any news on this Millworm?
In the meantime I received my digital caliper and thought I'd see what the physical differences were hopefully double making sure what they are.
90 423 010 (00 388 59 192) - assume this to be LET standard cam (inlet) - 42.5mm(L) x 34.1(w) +/- .1mm
90 423 011 - as above (exhaust) - 42.4(L) x 34mm(w)
90 322 027 (00 38859 022) - unsure if it is XE or LET (inlet) - 43.5(L) x 34mm(w)
2091358 469 (exhaust) - 43.3(L) +/- .1mm x 34mm(w)
2091358 489 (inlet) - 43.4mm(L) x 34.1mm(w)
2091358 072 (exhaust) - 43.5mm(L) +/- .1mm x 34.1mm(w)
Sorry mate on leave till wed so will get on then for you mate
Not getting anything back on those numbers mate, this is what i could find https://uploads.tapatalk-cdn.com/202...9bcd55cbe3.jpghttps://uploads.tapatalk-cdn.com/202...56da3930c2.jpg
Sent from my SM-G973F using Tapatalk
Hi Millworm, appreciate you taking the time to check.
I'm very surprised as to why these part numbers show no results, they obviously exist.
I'm not much closer to an proper answer, but thanks again.
Off to raid the web for info... again.
Tried them all, some were similar but none the same, and no evidence of them being revised numbers either i'm not a partsman so may be missing somthing but thats about all i can do
