Should come out then. Can you not guage which one it is from the centre of the clutch.
yeah I think its 1st cog just looked in an astra manual and that shows my type of box will have a look tomorrow and see. Ive read that the shafts are very tight will a slide hammer work ok ?
Front one I think...
http://img.photobucket.com/albums/v3...0519-00106.jpg
That is the F10 box on the Sport, had to take the cluster out on mine as it is a SCCR cluster :(
cheers for pic
Take a photo of the box with end plate removed but it's the input shaft should be near the top and inline with the shaft through the clutch there is a clip then a bolt Allen key I think that you remove then get a longer bolt the same thread thread that into the shaft and a pair of grips pull the shaft out that after you clip the clutch obvs
Slide hammer can be used if you are gentle. You do get a small one in the proper removal kit.
will take a pic thanks for help so far everyone
Ok big cog bottom left can just see the bolt set back in the photo
Cheers mate
