Timing belt change HELP!
Ok so I'm doing a timing belt change before I put the engine back in...
No no matter how many times I turn it over by hand I can't get the cam shaft pulleys lined to the notches on the cam cover and the crankshaft pulley lined to the pin...
I have the camshaft pulleys lined up but the crankshaft is out do I just put it back where it is now as it was running fine? Or do I line it up as it should
cheers
alex
Mine dont line up bang on , inlet is slightly back and outlet slightly forward I checked it with a timing gun and is right , work off cylinder 1 tbc
