hey guys, i asked this question in a few places, but didnt get any answers, and i thought, if anyone knows, you lot with your vauxhall wisdom, probably do.
the c16se engine - any idea if has the 3 threaded bolt holes on the side of the engine, next to the waterpump ? (triangular bolt pattern)
i was planning on putting that engine into a newer mk.4 astra, which uses a side mounted engine bracket, instead of the regular front mounted bracket.
they did fit 2 smallblock 8v's into those shells, the x16szr and the z16se, which both have the 3 bolt bracket setup, but there newer engines, and could have changed the design of the bottom ends, specifically for the fit ?
any info or pictures of the side of a c16 would be good thanks :thumb:
im just trying to make sure i dont get stuck, when it comes time to put it in
