The question is has anyone done it before and if so is there a build thread on it as id love to see https://uploads.tapatalk-cdn.com/201...c113efa4a8.jpg
Sent from my SM-G930F using Tapatalk
Autograss lads probs best to speak to as to what is avalible off the shelf for the job. I take it your going fwd
How you planning on mounting it? Rear engine rwd? Front engine rwd? Seen a few front engine rwd mk1 fiestas using bike engines
The ghetto way iv always imagined would work well would be a diff from an f20 say with a sprocket mounted to the bolts on it . Using a machined carrier ( bearings etc )
Mounted were a standard diff would be barring a frame holding the engine and the diff the rest of the car could stay standard in theoryhttps://uploads.tapatalk-cdn.com/201...a18718eb9d.jpg
Sent from my CLT-L29 using Tapatalk
Google ‘Opel Corsa C motorcycle engine’
There’s been a few of those which offer good inspiration.
Classic Minis and Hillman Imps are also a good hunting ground, loads of bike engined ones of those to crib from.
There’s a particularly nice Mini which runs at Gurston Down, with front mounted, FWD via Yamaha R1 motor.
Many years ago I bought a Nova with a Fireblade motor mounted up front. To the best of my knowledge it had never run in that format.
I broke the car for bits, it was a well fabricated thing using a proper Quaife reversing gear box (reverse is of course something to think about).
I think grassers use a starter motor for reverse if you get stuck
They do, it’s the cheap way to do it, acting directly onto a driveshaft is the common method.
As total-vauxhall mentions, grasstrackers are widely using this technology, worth a look is this website;
http://berrisford.co.uk/
