Find something like a piper BP285 cam & that thing will feel great
So only had half hour to play today. Refitted the weather strip across the bulkhead, Attached the start/charge loom, battery earth loom and my new expansion tank I got for pennies a year or 2 ago.
http://i1050.photobucket.com/albums/...ps1ix8o1tg.jpg
http://i1050.photobucket.com/albums/...psewin0tq3.jpg
Can anyone tell me if this extra earth cable is connected correctly please?
I'm only used to the single earth from the bulkhead to the battery but this one has an extra earth coming from it so I guess it attaches to the other battery terminal?
NOOOO you'll ark out the battery!
Don't worry it's not being wired up to any battery until at least the summer. Suggestions tho?
/cough flames
I've left it there so it's tucked out the way while other stuff gets finished. It looks like it should come into the bay somewhere as the connection will take a larger nut/bolt from the block, bigger than the battery one but cannot see how it comes through. Cannot see anything in the Haynes.
That earth wire connected to the positive battery terminial is a dead short when you connect battery back up. That long earth wire goes to the back of starter motor
So made up my first brake line last night. I purchased the full kit from eBay with the flares and fittings attached so just required bending. So far so good I think, have noticed it's been cut longer than the original so just need to adapt it to fit.
Also as I put the first pipe on the car I had to refit the servo and mc.
http://i1050.photobucket.com/albums/...pskukmtqem.jpg
