Tailgate skin was a mistake, didn't check part numbers when ordering! Might sack it off for a decent second hand one yet.
Started taking underseal off last night, in doing so I exposed some more bits that need attention.
A little bit and bottom of wheel arch
http://i95.photobucket.com/albums/l1...psrcmlahvt.jpg
Dug the fibreglass out of the front edge
http://i95.photobucket.com/albums/l1...ps3ojna0aa.jpg
I soon got bored of scraping so decided to cut out some rot. Firstly drilled off the drivers side flitch panel to get better access to repair the hole I could see from the back.
http://i95.photobucket.com/albums/l1...pszhbbxnyo.jpg
http://i95.photobucket.com/albums/l1...psdf3mfxgb.jpg
Then proceeded to cut out the bad boy ready to make up the repair section
http://i95.photobucket.com/albums/l1...psk3sqehvd.jpg
As I was then cleaning the surface up with wire wheel I came across more filler to from edge of strut top
http://i95.photobucket.com/albums/l1...psyhijvntf.jpg
Although not overly bad and repairable I'm now wanting a pair of inner wings as I want this to be mint when done, if I can't source any then will have to resort to repairing.
While on the hunt for panels, next job up is the battery tray.....
There always going on that strut top inner wing tbh I'd just plate that
It's been a few weeks since last update and made some reasonable progress. I managed to source a pair of inner wings thanks to Dave & Matt.
http://i95.photobucket.com/albums/l1...psihsmt6ky.jpg
So cracked on and cut out the right hand inner wing
http://i95.photobucket.com/albums/l1...psocdsitqa.jpg
Then while access was easier decided to sort the battery tray, cut out the rot
http://i95.photobucket.com/albums/l1...psd9p8mpkh.jpg
And trimmed the repair panel to shape, swaged the edges to allow the joint to sit flush
http://i95.photobucket.com/albums/l1...pseoahoo1a.jpg
Then welded it up, flattened it off and give a coat of etch
http://i95.photobucket.com/albums/l1...psswxm0te0.jpg
Then once that was inner fitted the new inner wing
http://i95.photobucket.com/albums/l1...psfb5yefie.jpg
And finally refitted the Flitch panel
http://i95.photobucket.com/albums/l1...psekxrjvny.jpg
Now on to the left hand side and do the same and I can then do the front panel. Feels good to making some progress now, hopefully the enthusiasm will continue!
Nice work. Also good to see the inner wings I sold you being used.
Dave.
I went to put wax in the cavities etc and ended up repairing a hole I discovered in my rear chasiss leg and three holes in the splash panels when preparing a Nova I just bought also described as "mint" by the seller. He was a twaat!
I have to say I am relieved to have not found as many things like you have but, good on you for doing the job properly, It will save you lots of hassle later on and you will know your Nova is solid. Why do people use fibreglass on decent cars?
nice work buddy.
Cheers lads, frustrating how people bodge things, just doubles the work. To be fair the lad I bought it off hadn't s clue about cars and when I pointed things out to him he was devastated.
I did similar work to a gte I had a coupe of years ago, took the flitch panel off like you've done repaired that area along with the battery tray I couldn't stretch to buying new panels tho. the previous owner had chicken meshed and fibre glassed most of the inner splash guards, what a bloody mess! nothing worse than fixing peoples bodges. will keep an eye on this build mate. you've made a nice start with it!
