f20 conversion
hi can anyone help I have a cross b got a x14xe in it and I have gone from a f13 to f20 the box is in but the shafts I am struggling with.
I have caviler ones but the drivers side yes is in but with not a lot of plunge on it at all
and the passenger side I can't get it in with bolting the hub to the suspension leg etc it seems to be too long.
does anyone know what shafts are the perfect fit or what I can do for the right fitment etc.
please help it is sending me crazy
Either conversion shafts and run a big outer flange wot h big bearings (strongest setup) or corsa gsi/sport 22 spline shafts with a mk2 cav inner cv joint to convert it to big block and retain standard hubs. You can cut down and sleeve the cab shafts but this will require big hubs also.
I have a pair of corsa b conversion shafts for sale and possibly 22 spline ones too
I have converted to the bigger hubs and flanges so I am f20 all round now I just can't seem to get these shafts right. so the conversion shafts you have will they fit my setup?
how much are we looking if they will fit?
thanks
They'll fit mate there made for a corsa b with f20 and big hubs. Needs an out cv joint on one shaft. 50 to you mate
yes mate I will take your advise and your help. what is your phone number so I can give you a message and we can sort out payment and if you don't mind posting them?
if not were about are you for pick up hopefully not to far.
many thanks
